How to set clock controller in BTS (board_test_system) for 32G (NRZ) MXP BTS example
Hi Ash_R:
I provide more information as follows
1. The current BTS (board test system) has been configured as MXPM_FGT x4
(25.78118Gbps) , and the loopback function works well.
2. if we change the clock rate using the clock controller (ex. OUT2
156.25MHz-->148.5MHz (or 184.32MHz) ), the system hangs.
How to change the clock for MXPM_FGT x4 32Gbps ?
Ming
Hi Ash_R:
We have updated the sequence to setup the clock (out2 set 184.32MHz) by configuring the "clock controller" first, setting OUT2 to 184.32MHz. (see attached file)
Next, we upload the "*.sof" (bts_mxpmn.sof) file to configure the FPGA for MXPM application.
The FPGA is currently operating at a 30.41274Gbps data rate right now, however we are unsure how to configure
the clock and achieve a 32Gbps data rate. it is very important for our application.
Could you please advise us on how to resolve this issue?
Ming
- ming0011 year ago
Hi Ash_R:
We still cannot figure out the solution to achieve a 32Gbps data rate.
Could you kindly take a look at this issue?
Really appreciate.
Ming
