MHEDA's avatar
MHEDA
7 years ago
How to set a multicycle path on my counter ? (if it is necessary)
My design works @125MHz. And for specific reason i need a 18 bits counter.
However, i choose to "relax" my design by using a shift register, and then use bit 0 and bit 3 to increment and to read the value of counter.
To do this, i hope that counter is less constraint. Am i wrong?
Moreover, i think that i can use a multicycle path constraint in order to avoid some timing analysis warnings. Is it correct or am i saying a big stupidity ?
Thanks for all.
Here is an extract of my design file.
The warning is for example between counter and output assignement.
For information: the design must run on an old Altera Max2.
signal shit_en : std_logic_vector(3 downto 0;
signal cnt : std_logic_vector( 17 downto 0);
begin
    process(clk, rst_n)
    begin
        if rst_n = '0'  then
            shit_en <= "0001" ;
        elsif rising_edge( clk ) then
            shit_en <= shit_en(2 downto 0) & shit_en(3);
        end if;
    end process;
    process(clk, rst_n)
    begin
        if rst_n = '0'  then
            cnt <= ( others => '0');
            if ( shit_en(0) = '1' ) then
                cnt <= cnt + 1;
            end if;
        end if;
    end process;
    process(clk, rst_n)
    begin
        if rst_n = '0'  then
            out_a <= '0';
            if ( shit_en(3) = '1' and cnt <= "10" & x"1011" ) then
                out_a <= '1';
            else
                out_a <= '0';
            end if;
        end if;
    end process;
  • SreekumarR_G_Intel's avatar
    SreekumarR_G_Intel
    Hello ,
    sorry for very late response ;
    Can you give me more information as suggested by the above post ?
    Thank you ,
    Sree
  • sstrell's avatar
    sstrell
    What version of Quartus are you using? I don't know if MAX 2 is even supported by SDC and the timing analyzer. And what is the warning you are getting?
    On a side note, you're missing parentheses on line 1, and I'm guessing your signal is supposed to be shift_en (what you have right now is a curse in English!).
    #iwork4intel
