How to program an ALTPLL_RECONFIG core?
Hi All,
I using the ALTPLL_RECONFIG core on a CycloneIV and it seems to work fine except that I can't seem to duplicate the initial state mif file settings.
When I simulate the core I get clk0=100MHz and clk1=400KHz, I then reconfigure the core using the initial state mif file setting and I get the correct clk0=100MHz but clk1=1.2MHz which is 3 times as high. The core reports:
# clk0 : C0 : high = 3 (3) , low = 3 (2) , mode = even ( odd) , phase tap = 0 (0)
# clk1 : C1 : high = 250 (625) , low = 250 (625) , mode = even ( even) , phase tap = 0 (0)
# unused : C2 : high = 256 (5) , low = 256 (5) , mode = even ( even) , phase tap = 0 (0)
# unused : C3 : high = 256 (5) , low = 256 (5) , mode = even ( even) , phase tap = 0 (0)
# unused : C4 : high = 256 (5) , low = 256 (5) , mode = even ( even) , phase tap = 0 (0)
# Charge Pump Current (bit setting) = 0 ( 0 )
# Loop Filter Capacitor (bit setting) = 0 ( 0 )
# Loop Filter Resistor (bit setting) = 27 ( 0 )
# VCO_Post_Scale = 2 ( 2 )
What is confusing to me is the previous C1 value (in brackets) should be 625, how do I program 625 when the clk1 counter is only 8 bits? The initial mif file indicates a value of 250 which I used, so I must have missed a settings?
Here is part of the mif file:
-- MIF file representing initial state of PLL Scan Chain
-- Device Family: Cyclone IV E
72 : 0; -- clk1 counter: Bypass = 0 (1 bit(s))
73 : 1; -- clk1 counter: High Count = 250 (8 bit(s))
74 : 1;
75 : 1;
76 : 1;
77 : 1;
78 : 0;
79 : 1;
80 : 0;
Hans.
- AnandRaj_S_Intel
Hi Hans,
Thanks for sharing the information which will help the community.
Anand
- hans86
Hi Anand,
Thanks for the follow up, I found the answer to my point 1, as described in the CycloneIV Device Handbook from 2016 it states:
Post-scale counter cascading is automatically set by the Quartus II software in the configuration file. Post-scale counter cascading cannot be performed using the PLL reconfiguration.
I was using the ALTPLL (Phase-Locked Loop) IP Core User Guide and the Phase-Locked Loop Reconfiguration (ALTPLL_RECONFIG) IP Core User Guide both from 2017 neither mention this fact. It explains the C1 value of 625 which a user can't get to with an 8 bits register.
So the conclusion is that the values defined during Quartus IP configuration cannot all be reproduced using the ALTPLL_RECONFIG or with the mif file.
I think a warning during the ALTPLL configurations (when users click the dynamic configuration option and uses a too low frequency) would be very helpful.
Thanks for replying you did give me a good hint to investigate the mif file,
Hans.
- hans86
Hi Anand,
Thanks for replying, I checked the mif file and it is definitely being read by the ALTPLL_RECONFIG core.
However, given that the (ALTPLL generated) mif file is loaded into the ALTPLL_RECONFIG core a single reconfig pulse should not change the clk0/cl1 values right? Unfortunately this is not the case, both clock signals change to different values.
I then used the read_param signal to read back the cached values after reset and all I get back is zeros for the N/M/clk0/clk1 counters. This is strange as I can see the mif values being loaded into an altsyncram4 block during simulation. If I use the read_param signal after I programmed the ALTPLL_CONFIG myself I get all the right values (the ones I programmed in) so the read back is working.
So my findings are that:
1) The ALTPLL generate mif file loaded into the ALTPLL_RECONFIG core does not give the same results as using the Quartus generated ALTPLL values.
2) You cannot read back the ALTPLL_RECONFIG cached values until you have programmed the core.
I am sure the first one is incorrect as CycloneIV is not new and many customers must have used the ALTPLL_RECONFIG core successfully but I can't make it work, any clue as to what is going on?
Hans.
- AnandRaj_S_Intel
>>Single pulse is enough to trigger the reconfiguration but clk0 and clk1 values will change after busy signal deassert.
>>Do you mean mega-wizard generated mif is file is not working and Qsys generated mif file is working??
>>Yes, You are correct.
Anand
- AnandRaj_S_Intel
Hi Hans,
Check if .mif file is included in your Altera PLL Reconfig IP. Enable the mif streaming and give mif path.
Anand
