How to program an ALTPLL_RECONFIG core?
Hi Anand,
Thanks for the follow up, I found the answer to my point 1, as described in the CycloneIV Device Handbook from 2016 it states:
Post-scale counter cascading is automatically set by the Quartus II software in the configuration file. Post-scale counter cascading cannot be performed using the PLL reconfiguration.
I was using the ALTPLL (Phase-Locked Loop) IP Core User Guide and the Phase-Locked Loop Reconfiguration (ALTPLL_RECONFIG) IP Core User Guide both from 2017 neither mention this fact. It explains the C1 value of 625 which a user can't get to with an 8 bits register.
So the conclusion is that the values defined during Quartus IP configuration cannot all be reproduced using the ALTPLL_RECONFIG or with the mif file.
I think a warning during the ALTPLL configurations (when users click the dynamic configuration option and uses a too low frequency) would be very helpful.
Thanks for replying you did give me a good hint to investigate the mif file,
Hans.
