How to program an ALTPLL_RECONFIG core?
Hi Anand,
Thanks for replying, I checked the mif file and it is definitely being read by the ALTPLL_RECONFIG core.
However, given that the (ALTPLL generated) mif file is loaded into the ALTPLL_RECONFIG core a single reconfig pulse should not change the clk0/cl1 values right? Unfortunately this is not the case, both clock signals change to different values.
I then used the read_param signal to read back the cached values after reset and all I get back is zeros for the N/M/clk0/clk1 counters. This is strange as I can see the mif values being loaded into an altsyncram4 block during simulation. If I use the read_param signal after I programmed the ALTPLL_CONFIG myself I get all the right values (the ones I programmed in) so the read back is working.
So my findings are that:
1) The ALTPLL generate mif file loaded into the ALTPLL_RECONFIG core does not give the same results as using the Quartus generated ALTPLL values.
2) You cannot read back the ALTPLL_RECONFIG cached values until you have programmed the core.
I am sure the first one is incorrect as CycloneIV is not new and many customers must have used the ALTPLL_RECONFIG core successfully but I can't make it work, any clue as to what is going on?
Hans.
>>Single pulse is enough to trigger the reconfiguration but clk0 and clk1 values will change after busy signal deassert.
>>Do you mean mega-wizard generated mif is file is not working and Qsys generated mif file is working??
>>Yes, You are correct.
Anand
