12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years agoyou can create onchip(or external)RAM.
and you can create ram -initializ like following (this is verilog-HDL sorry) //////////////////////////////////////////////////////////////////////////////////////////////// reg [WORD_WIDTH-1:0]pattern_rom[0:2**ADDR_WIDTH]; initial $readmemh( "ROM_HEX_FILE.txt",pattern_rom); reg [WORD_WIDTH-1:0]outbuff; always @ ( posedge csi_clk ) begin outbuff <= pattern_rom[reg_read_addr]; end assign wir_read_data = outbuff; //////////////////////////////////////////////////////////////////////////////////////////////// ROM_HEX_FILE.txt is initial data of pattern_rom. anyway, there is a way you can create table. but I am not sure you really have big enough memory on your FPGA.
