How to manually trigger or inhibit periodic OCT updates in Arria 10
Hi
You can change the periodic OCT option in the EMIF IP GUI parameter.
- SLabe5 years ago
Hi, the GUI only lets permanently enable or disable Periodic OCT Calibration. What we need is the ability to selectively block it during critical data transfers and then re-enable it the rest of the time to compensate for temperature cycling, etc ...
According to 3.4.3: https://www.intel.com/content/www/us/en/programmable/documentation/eqw1503946000045.html#mhi1460567996227 there is a way to do this, but requires your support. My local Intel resource indicated some lower level code may need changing to expose the appropriate controls.
Thank you,
- yoichiK_altera5 years ago
Contributor
Hi
There is file to control the periodic OCT update and you can tweak the oct_recal_req signal in the file to enable or disable the periodic OCT.
ip/ed_synth/ed_synth_emif_0/altera_emif_arch_nf_191/synth/altera_emif_arch_nf_oct.sv
