How to manually trigger or inhibit periodic OCT updates in Arria 10
As mentioned in A10 EMIF UG, looking for information on the following statement:
"Contact Intel FPGA Technical Services for information on how to manually trigger or inhibit periodic OCT updates for applications that are sensitive to latency."
Please share the solution so I can enable my customer. Thank you,
- Ben_C
Hi
Are you sure it's oct_recal_req and not oct_cal_req?
Maybe I'm wrong but oct_recal_req output goes to c2t_afi[6] in altera_emif_arch_nf_seq_if.sv and that's it. No other action is done. On the other hand, the oct state machine triggers with oct_cal_req.
Thank you- yoichiK_altera
Contributor
I was bit inaccurate. not oct_cal_req ,but r_oct_cal_req signal in the RTL to disable it. oct_cal_req is the signal used during the power up.
Here is the example RTL change to disable periodic OCT update.
always_ff @(posedge w_oct_clock)
begin
if (w_oct_reset == 1'b1)
begin
r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-1)] <= 1'b0;
r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-2):0] <= OCT_RECAL_TIMER_PRESET[(OCT_RECAL_TIMER_WIDTH-2):0];
r_oct_recal_req <= 1'b0;
end
else if (user_oct_disalbe) // added, user interface signal.
r_oct_recal_req <= 1'b0; // added, disable periodic OCT
else
begin
if (r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-1)] == 1'b1)
begin
r_oct_recal_req <= ~r_oct_recal_req;
end
else
begin
r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-1):0] <= r_oct_recal_timer[(OCT_RECAL_TIMER_WIDTH-1):0]
- {{(OCT_RECAL_TIMER_WIDTH-1){1'b0}}, 1'b1};
end
end
end
- yoichiK_altera
Contributor
Hi
You can change the periodic OCT option in the EMIF IP GUI parameter.
- SLabe
Hi, the GUI only lets permanently enable or disable Periodic OCT Calibration. What we need is the ability to selectively block it during critical data transfers and then re-enable it the rest of the time to compensate for temperature cycling, etc ...
According to 3.4.3: https://www.intel.com/content/www/us/en/programmable/documentation/eqw1503946000045.html#mhi1460567996227 there is a way to do this, but requires your support. My local Intel resource indicated some lower level code may need changing to expose the appropriate controls.
Thank you,
- yoichiK_altera
Contributor
Hi
There is file to control the periodic OCT update and you can tweak the oct_recal_req signal in the file to enable or disable the periodic OCT.
ip/ed_synth/ed_synth_emif_0/altera_emif_arch_nf_191/synth/altera_emif_arch_nf_oct.sv
