16 years agoHow to keep logic not being optimized away?
Hi guys: For some applications, I need insert some logic cells in my design. How to keep these logic? Another question is anyone know what is the delay range of one logic cell? 4 ns? or...
16 years agoTo prevent logic cell optimization precisely for particular nodes, I suggest to use HDL synthesis attributes.
The below example prevents removal of the signal my_wire.signal my_wire: bit;
attribute syn_keep: boolean;
attribute syn_keep of my_wire: signal is true; More examples can be found in the Quartus II Software Handbook and in the advanced synthesis cookbook. http://www.altera.com/literature/man...x_cookbook.pdf P.S.: Because you mentioned CPLDs. Unfortunately, many settings to keep logic cells are ignored by the Quartus CPLD fitter. I'm not sure, if there's a way to achieve it at all. 200 ns would be far above a reasonable logic cell delay anyway.
