How to instance SDRAM controller in DE10 Lite?
I am trying to fill the SDTAM chip on the DE10 Lite from Quartus, using a .mif file.
From what I read , the SDRAM is DDR4, yet in the IP catalog includes DDR2/DD3/LPDDR2 with UniPhy.
Which instance should be used for that?
I am not really sure why is that needed, since at this stage the FPGA is not part of the process, right?
The data that is written into the SDRAM is transferred from the host (Quartus) directly into the SDRAM chip.
Is that correct?
After this is done, the plan is to fill the DE10 Lite external SDRAM with content from Quartus command line.
- Clearly ease of use. Works without installing JTAG stack (at least Standalone-Programmer) on the client computer.
Altera/Intel RS232 UART IP uses AVMM interface which I don't need in basic HDL debug logic design. I have simple Rx and Tx code with fixed baudrate (921k) written from the scratch. There's no code I can send you as is, I'll check if I can extract something. There are however tons of UART code on the net.
- YigalB1
Thank you for clarifying. I was hoping to create some kind of automating a transfer of data from the host to the FPGA, few KB each time, and automatically getting back few bytes from the FPGA to the host, to allow usage of the FPGA as a tester: run a test based on the input data, and send back the results, so the host could compare expected vs actual results.
Using the internal RAM could provide such a solution, but it seems no way to do this, but it looks like no way to do it.
In this case implementing UART on the FPGA and using FTDI from the USB of the host to the GPIOs on the FPGA seems the only valid method. Is it?
Thank you for answering.
- FvM
I have test applications communicating with FPGA through JTAG and debug IP (Source&Probe and In-System Memory Content Editor). That's definitely possible. Nevertheless I switched to UART interface with newer designs.- YigalB1
1) Why did you switch to UART? Performance? Ease of use?
2) What UART did you use? The "RS232 UART" from the IP catalog?
3) can you share your code for both options?
- sstrell
No, you can't initialize an off-chip RAM with a .mif. That is for initializing on-chip RAM during device programming only.
- YigalB1
Thank you.
What about instancing the SDRAM?
Is that doable from the Quartus side? Like other IPs?
- sstrell
Do you mean "instantiating"? If the target device supports it, it will be available in the IP Catalog. If DDR4 does not appear there, then it is not supported, which makes sense for an old DE10 board (Cyclone V I believe). https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=167&No=1046&PartNo=2#contents
