16 years ago
how to infer out of module to be register
hello
i want to know how can i make output of the module to be registers (not combinational logic) ?
    You just need to assign the signal in a edge triggered process, instead of making a continuos assignment.
    For example, in Verilog
    module my_module(
    input wire clk,
    input wire rx,
    output wire tx1
    output reg tx2
    output reg tx3
    assign tx1 = !rx;
    always @ (*) tx2 <= !rx;
    always @ posedge (clk) tx3 <= !rx;
    endmodule
    In VHDL
    entity my_module is
    port(
    clk : in std_logic;
    rx : in std_logic;
    tx1 : out std_logic;
    tx3 : out std_logic;
    end my_module;
    architecture rtl of my_module is
    begin
    tx1 <= not rx;
    process (clk)
    begin
    if clk'event and clk = '1' then
    tx3 <= not rx;
    end if;
    end process;
    end rtl;
    tx1 and tx2 will be just combinational logic, while tx3 will be registered
    will register be the output of this 7 segment transofrmer ?
    library ieee;
    use ieee.std_logic_1164.all ;
    use ieee.std_logic_arith.all;
    entity decoder7seg is
        port (DIGIT : in std_logic_vector(3 downto 0);
                SEG : out std_logic_vector(6 downto 0) );
    end entity decoder7seg;
    architecture decoder7seg_a of decoder7seg is
        begin
          --decode : process DIGIT is
          SEG <= "0111111" when DIGIT="0000" else   -- 0
                 "0000110" when DIGIT="0001" else   -- 1
                 "1011011" when DIGIT="0010" else   -- 2
                 "1001111" when DIGIT="0011" else   -- 3library ieee;
                 "1100110" when DIGIT="0100" else   -- 4
                 "1101101" when DIGIT="0101" else   -- 5
                 "1111101" when DIGIT="0110" else   -- 6
                 "0000111" when DIGIT="0111" else   -- 7
                 "1111111" when DIGIT="1000" else   -- 8
                 "1101111" when DIGIT="1001" else   -- 9
                 "1110111" when DIGIT="1010" else   -- A
                 "1111100" when DIGIT="1011" else   -- b
                 "0111001" when DIGIT="1100" else   -- C
                 "1011110" when DIGIT="1101" else   -- d
                 "1111001" when DIGIT="1110" else   -- E
                 "1110001" when DIGIT="1111" else   -- F
                 "0000000";
        end architecture decoder7seg_a;
