15 years agoHow to increase performance (Transfer rate) of DMA core?
I want to know how can i transfer from my SRAM to my SDRAM in the fastest possible way. I've been able to transfer data from SRAM to SDRAM using DMA at the transfer rate of 66MB/s when NIOS2, DMA, SRAM, and SDRAM were clocked at 100MHz. Is this a reasonable number? Then i increased the clock to 125MHz, i am able to get 83.27MB/s transfer rate. Then when i further increase it to 150MHz, there will be errors in the data transferred to the SDRAM. Now how do i make it go faster from this point? can i clock the DMA, SDRAM, and SRAM higher without messing with the CPU's clock? Michael4 Replies
--- Quote Start --- Which DMA are You using? SGDMA has way much better results than simple DMA. Nios systems running above 100MHz needs to be timing constrained very well. --- Quote End --- I am using DMA. SGDMA is hard to understand, i am still struggling with it, do you have a simple example involving SGDMA? like transferring ST to memory or memory to memory? What if i do not do any timing constraint on NIOS2? what will happen? I thought the .sdc file is generated by SOPC builder automatically after HDL is generated? so all i have to do is just include the cpu.sdc into the timequest timing analysis? Michael - Altera_Forum
--- Quote Start --- You may use a dual clock bridge to run different pieces of your SOPC at different clock frequencies. --- Quote End --- Do you mean Avalon-MM clock crossing bridge? if yes, how do i connect DMA, and 2 memory blocks and attach it to the clock crossing bridge? Michael - Altera_Forum
Nios systems running above 100MHz needs to be timing constrained very well. - Altera_Forum
