17 years ago
how to increase frequency
I have written a code in Verilog and its frequency is comming out to be 28MHz only for Cyclone EPC6Q240C8 device.
The place where frequency drops is Average Calculation.
I have 3 registers 24bit each.
Say,
reg1 [23:0]
reg2 [23:0]
reg3 [23:0]
each of these registers contain 8 bit data. And I need to calculate the average of these nos.
So, how I am doing is:
always block 1
sum1 <= reg1[23:16] + reg1[15:8] + reg1[7:0];
sum2 <= reg2[23:16] + reg2[15:8] + reg2[7:0];
sum3 <= reg3[23:16] + reg3[15:8] + reg3[7:0];
always block 2
sum4 <= sum1 + sum2 + sum3;
always block 3
average <= (my conditions)? sum4 / 9 : average;
average_valid <= (my conditions)? 1'b1 : 1'b0;
Simply by eleminating this part of code, the frequency of my design shoots to 70MHz.
So, please can anyone provide me with an alternative approach to calculate the average without compromising with the frequency.
Thank you,
-Amit
    So the design is already completely pipelined. The /9 divider should be suspected as the slowest part. But it's likely to achieve more than 28 MHz to my opinion, unless you're stuck to a very slow device family. There must be something else, not understandable from the shown part, e. g. additional timing constraints related to the in and output signals. As pletz suggested, you have to examine the timing analysis details.
    --- Quote Start ---
    reg [9:0] sum1;
    reg [9:0] sum2;
    reg [9:0] sum3;
    reg [11:0] sum4;
    always @ (posedge core_clk or negedge reset_n)
    begin
    if(!reset_n)
    begin
    sum1 <= 10'd0;
    sum2 <= 10'd0;
    sum3 <= 10'd0;
    end
    else
    begin
    sum1 <= row1_reg[23:16] + row1_reg[15:8] + row1_reg[7:0];
    sum2 <= row2_reg[23:16] + row2_reg[15:8] + row2_reg[7:0];
    sum3 <= row3_reg[23:16] + row3_reg[15:8] + row3_reg[7:0];
    end
    end
    begin
    if(!reset_n)
    sum4 <= 12'd0;
    else
    end
    begin
    if(!reset_n)
    begin
    average <= 12'd0;
    avg_valid <= 1'b0;
    end
    else
    begin
    average <= (valid_flag_r && red_pulse) ? sum4 / 9 : average;
    avg_valid <= ((valid_flag_r && red_pulse) || (valid_flag_g && green_pulse)
    || (valid_flag_b && blue_pulse))? 1'b1 : 1'b0;
    end
    end
    This is basically a part of Average and Median Filter Implementation.
    Right now I am working with 16MHz clock and taking my output through RS232 at 38.4 kbps. But say if I have to work with 48MHz clock with 115 kbps RS232 baud rate, my design won't work!!
    --- Quote End ---
    in which always block is the longest path located ?
    Kind regards
    GPK
    reg [9:0] sum1;
    reg [9:0] sum2;
    reg [9:0] sum3;
    reg [11:0] sum4;
    begin
    if(!reset_n)
    begin
    sum1 <= 10'd0;
    sum2 <= 10'd0;
    sum3 <= 10'd0;
    end
    else
    begin
    end
    end
    begin
    if(!reset_n)
    sum4 <= 12'd0;
    else
    end
    begin
    if(!reset_n)
    begin
    average <= 12'd0;
    avg_valid <= 1'b0;
    end
    else
    begin
    end
    end
    You forgot to mention the most important point: Is it a combinational or edge sensitive always block. The speed result seems likely for a combinational one.
    However, without considering the role of a clock in the design, the speed results are more or less meaningless. The discussion would be much easier, if you provide a complete design, including a clock.
    Practically, you have a clock speed requirement, e.g. 50 MHz. Then the result means, that it isn't possible to perform the complete chain of caculations in one clock cycle. You have to split it across it at least two cycles. This is done automaticly by using edge sensitive always blocks. But you have to know first, how your input and output variables are related to the clock. However, if you intend to perform the complete calculation within a 50 MHz cycle, the result simply means: Give it up!
