seamusbleu
3 years agoHow to handle Stratix10 HPS-to-FPGA bridge ID width mismatch
The h2f_axi_master in the s10_hps has ID widths (AWID/ARID/RID/BID) of 4. I connect it to my custom IP which also has an ID width of 4 but platform designer complains that the ID width must be 5. I...
- 3 years ago
So what you're saying is that there is no solution to this problem - that is not helpful.
seamusbleu
3 years agoPlease show me how to use an AXI bridge to connect the slaves and masters together such that the ID widths can be different on the respective sides.
As I stated in the original post:
>This forum post suggests adding an AXI bridge. But that doesn't work as the AXI bridge requires the ID widths on both sides be the same.
