seamusbleu
3 years agoHow to handle Stratix10 HPS-to-FPGA bridge ID width mismatch
The h2f_axi_master in the s10_hps has ID widths (AWID/ARID/RID/BID) of 4. I connect it to my custom IP which also has an ID width of 4 but platform designer complains that the ID width must be 5. I...
- 3 years ago
So what you're saying is that there is no solution to this problem - that is not helpful.
tehjingy_Altera
3 years agoHi seamusbleu
The reason behind the question before is to rule out any possibility.
I just got an advice from my senior that the AXI ID width of the HPS is not able to be changed.
As for the connection you have the hang is expected as the axi transactioin is exceeding the axi id value.
To solve the error in quartus, you could use the AXI bridge to connect the slaves and master together.
The mismatch in the AXI ID width is still be able to be connected but in the AXI transaction you will need to bare in mind to not exceed the maximum id value of the lesser ID width.
Jingyang, Teh
