seamusbleu
3 years agoHow to handle Stratix10 HPS-to-FPGA bridge ID width mismatch
The h2f_axi_master in the s10_hps has ID widths (AWID/ARID/RID/BID) of 4. I connect it to my custom IP which also has an ID width of 4 but platform designer complains that the ID width must be 5. I...
- 3 years ago
So what you're saying is that there is no solution to this problem - that is not helpful.
seamusbleu
3 years agoDo a "git clone https://github.com/altera-opensource/ghrd-socfpga.git ghrd-socfpga", then apply the changed files in the attached archive, then do a "make generate_from_tcl" and then "make quartus_edit", then open the qsys_top.qsys file and you will see the warnings shown above.
