14 years agoHow to fix timing Violations
I am a ASIC guy new to FPGA design
Generally how do I fix timing violations? Can I speedup the source path by forcing better placement? This is the timing violation on a 156 Mhz path Total ; Incr ; RF ; Type ; Fanout ; Location ; Element ; +---------+---------+----+------+--------+------------------+-----------------------------------------------------------------------------------------------------------------------------+ ; 0.000 ; 0.000 ; ; ; ; ; launch edge time ; ; 6.490 ; 6.490 ; ; ; ; ; clock path ; ; 6.490 ; 6.490 ; R ; ; ; ; clock network delay ; ; 9.608 ; 3.118 ; ; ; ; ; data path ; ; 6.558 ; 0.068 ; ; uTco ; 67 ; M144K_X93_Y41_N0 ; altera_avalon_dc_fifo_top:dc_fifo_top_0|altsyncram:mem_rtl_0|altsyncram_89n1:auto_generated|ram_block1a0~portb_address_reg0 ; ; 8.527 ; 1.969 ; RR ; CELL ; 1 ; M144K_X93_Y41_N0 ; dc_fifo_top_0|mem_rtl_0|auto_generated|ram_block1a0|portbdataout[65] ; ; 9.414 ; 0.887 ; RR ; IC ; 1 ; FF_X75_Y48_N35 ; dc_fifo_top_0|out_payload[68]|asdata ; ; 9.608 ; 0.194 ; RR ; CELL ; 1 ; FF_X75_Y48_N35 ; altera_avalon_dc_fifo_top:dc_fifo_top_0|out_payload[68] ; +---------+---------+----+------+--------+------------------+-----------------------------------------------------------------------------------------------------------------------------+ +-------------------------------------------------------------------------------------------------------------------+ ; Data Required Path ; +---------+---------+----+------+--------+----------------+---------------------------------------------------------+ ; Total ; Incr ; RF ; Type ; Fanout ; Location ; Element ; +---------+---------+----+------+--------+----------------+---------------------------------------------------------+ ; 6.400 ; 6.400 ; ; ; ; ; latch edge time ; ; 8.843 ; 2.443 ; ; ; ; ; clock path ; ; 8.596 ; 2.196 ; R ; ; ; ; clock network delay ; ; 8.843 ; 0.247 ; ; ; ; ; clock pessimism ; ; 8.823 ; -0.020 ; ; ; ; ; clock uncertainty ; ; 8.763 ; -0.060 ; ; uTsu ; 1 ; FF_X75_Y48_N35 ; altera_avalon_dc_fifo_top:dc_fifo_top_0|out_payload[68] ; Thanks2 Replies
Thanks for the reply
It is failing by .845ns I will study further on how to improve clock skew and redirect placement - Altera_Forum
You left some stuff out, but yes, you should be able to get better timing. Your hop is from X93_Y41 to X75_Y41, and so is a ~18 LAB hop that takes almost 2ns. Getting it closer should easily shave off 1 ns. How much is it failing by?
Probably just as important, if not more, is that your source clock is 6.49ns while the latch clock is 2.443ns. So you're losing a little over 1ns on the data path, but you're loosing 4ns due to clock skew. Run report_timing with the -detail set to "full_path" and analyze the clock skew. If you can fix something there, it would have a larger impact.
