eran_el
4 years agoHow to fit 2 multipliers in one DSP block - Arria V?
In a project done using Arria V FPGA (5AGXFB1HF35I3), I'm using an IP (LPM_MULT) with the following properties:
dataa and datab input width - 16bit
result output width - 32bit
Signed
Two cl...
eran_el
4 years agoHi,
If you're talking about what they're saying here:
The following Intel® Quartus® Prime IP cores are supported for the Arria® V variable precision DSP blocks implementation:
- LPM_MULT
- ALTERA_MULT_ADD
- ALTMULT_COMPLEX
- ALTMEMMULT
Then yes, I've used the LPM_MULT IP.
