17 years agoHow to finish the altpciechdma.c driver?
I've downloaded the altpciechdma.c driver for the Altera Arria GX dev kit.
The char part of it is not yet finished (due to the comments). And a module is missign "mapper_user_to_sg.h". Smb has tried to finish this part of the driver by himself? Or maybe I've missed the "mapper_user_to_sg.h" module? I need to talk to the driver from userspace. (Using LInux 2.6.25)22 Replies
Thank you for reply. I find the driver's write operation is use anther way to do the DMA map,and i can't verify if that map way have more efficiency. The driver author Leon also replied: We found that we could not make user SGDMA work reliably with the IP provided by Altera. Direct I/O user scatter-gather DMA was introduced in a commercial PCI Express IP core for Altera FPGA's: http://www.lancero.eu.com/lancero-pcie-sgdma/ - Altera_Forum
the driver had enough code to test the connection between the FPGA and the kernel of the system. If I am not wrong, those functions were meant to provide data transfer between kernel space and user space. The functions that were allocated in those files are commented in the general code (not used). If your intention is to provide access from user space, then you should search on driver development and check functions such as copy_to_user and copy_from_user. As I did in my case, you have to finish it up. I hope it was of any help. P.D. I couldn't find it either - Altera_Forum
I can't find the file "mapper_user_to_sg.h" and "user_dma_sg.c". The web http://www.sidebranch.com/leon/user_dma_sg.c svn.assembla.com/svn/altpciechdma/user_dma_sg.c also can't be visit. There is any advise for me? Thanks. - Altera_Forum
Thanks arco!
I would like to get anyone opinions on http://www.alterawiki.com/wiki/linux_pcie_driver and ftp://ftp.altera.com/up/pub/altera_material/12.1/tutorials/using_pcie_on_de4.pdf It seems easier due to Qsys.. Thanks alot in advance! - Altera_Forum
Sorry for my late reply,
the parameter I mention is located on the VHDL/Verilog design. I am not aware if it is possible to access it from Qsys. I hope it solved any doubt on your design. Anyway, good luck and patience. - Altera_Forum
thanks arco,
I found it in pcie_ddr2_a2gx. it is not so obvious in qsys (perhaps none). this will set the appropriate TLP in altpcierd_cdma_app_icm_ddr which eventually controls altpcierd_dma_dt, etc... i was thinking to do my hardware development with reference design with qsys since it is simpler, but i think pcie_ddr2_a2gx is more detailed in implementations also complex. or do you know how to set these things in Qsys? thanks once again. - Altera_Forum
Hi de_prince,
it is found in module app_chaining as RC_64BITS_ADDR. When set to 1, the design is capable to communicate with DMA that can handle 64 bit addresses Found it? - Altera_Forum
Hi arco,
what do you mean by 64-bit manageable DMA? and where to find this generic parameter? I am doing exactly what you are doing. Thanks. - Altera_Forum
most of you might have already found a solution for your problems. I just would like to point out a few things regarding altpciechdma driver. I have managed to make it run on a Ubuntu 10.04 64 bits. Some of you have an error where the dma loopback test do not match the transfer (as if no buffer overwrite is performed). if your system has a 64 bit manageable DMA, the driver might recognise the PCI implementation as capable, but the hardware has to know it too. There is a generic parameter on the chain-dma design where compatibility for 64 RC DMA modules must be configured. On the other hand, I am now trying to use the driver to build the character/block device required to keep working. If anyone has some experience on this, it would be nice to have some suggestions on how I should proceed. Thanks to everyone - Altera_Forum
Hi haulisson,
I have a similar problem to yours, what exactly did you modify in the driver setup to get teh dma test to work or did you have to change the settings in the hard-ip? Thanks
