17 years agoHow to finish the altpciechdma.c driver?
I've downloaded the altpciechdma.c driver for the Altera Arria GX dev kit. The char part of it is not yet finished (due to the comments). And a module is missign "mapper_user_to_sg.h". Smb has...
12 years agoHi,
Thank you for reply. I find the driver's write operation is use anther way to do the DMA map,and i can't verify if that map way have more efficiency. The driver author Leon also replied: We found that we could not make user SGDMA work reliably with the IP provided by Altera. Direct I/O user scatter-gather DMA was introduced in a commercial PCI Express IP core for Altera FPGA's: http://www.lancero.eu.com/lancero-pcie-sgdma/
