12 years agoHow to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... p...
12 years agonow i change to these codes and the output as shown in picture attachment...
input wire Enable; input wire [9:0] d_in; output reg [9:0] max_value; output reg [2:0] max_location; reg [2:0] Q; initial begin max_value = 0; end always @ (posedge clock) begin if (Enable) begin if (d_in > max_value) begin max_value <= d_in; max_location <= Q; end Q <= Q + 1; end end endmodule
