vfraloo
4 years agoHow to disable multiple reconfiguration profile when I only use one of them?
I'm using 1G/2.5G/5G/10G Multi-rate Ethernet PHY Intel® Stratix® 10 FPGA IP to implement 1G Ethernet. I choose the external PHY to MGBASE-T, and the PHY speed is 1G/2.5G. There are two reconfig...
paveetirrasrie_Altera
4 years agoHi rain Bow,
Apologize for the delay.
Transceiver PHY dynamic reconfiguration interface—an Avalon-MM interface to read and write the Intel Stratix 10 Native PHY IP core registers. This interface supports dynamic reconfiguration of the transceiver. It is used to configure the transceiver operating modes to switch to desired Ethernet operating speeds. I believe you cant disable it but instead you can switch it.
Pavee
