vfraloo
4 years agoHow to disable multiple reconfiguration profile when I only use one of them?
I'm using 1G/2.5G/5G/10G Multi-rate Ethernet PHY Intel® Stratix® 10 FPGA IP to implement 1G Ethernet. I choose the external PHY to MGBASE-T, and the PHY speed is 1G/2.5G. There are two reconfig...
paveetirrasrie_Altera
4 years agoHi Rain Bow,
To change the PHY speed, kindly use the reconfiguration block in the MAC+PHY example design.
For more detailed steps, refer to Multi rate Ethernet UG page 21 4.3. Switching Operation Speed :
When you configure the PHY in 1G/2.5G configuration, Intel recommends that you add the following constraint in the timing constraint file. Kindly refer to page 20 for the Timing Constraint.
Pavee
vfraloo
4 years agoHi,
I'm not trying to know how to switch speed, I only want to know how to disable Quartas analyze timing for 2.5G speed, 1G is enough for my design.
