JerryYau
4 years agoHow to disable "Device automatically loads secondary image" for MAX 10 FPGA
Hi sir,
I am using MAX10 FPGA to design my product. In this project, the configuration mode is Dual Compressed Images and enable CONFIG_SEL pin to select which image to boot up the FPGA.
And th...
- 4 years ago
There is no option to disable the automatically loads secondary image. If image fail to load, it will revert back to factory image/ initial image.
Aiman
NurAiman_M_Intel
4 years agoHi,
May I know if "Device automatically loads secondary image" give any error for your project?
I hope you notice that if error occur, it can only fallback to CFM1 once. But it will always fall back to CFM0 as CFM0 is the golden image.
Please see below;
Kindly refer to the image uploaded.
Aiman
JerryYau
4 years agoHi,
No, just want to disable automatically load the other image function.
B/R
Jerry Yau
