15 years agoHow to disable all unused LEDs and 7 segment display on DE2 board?
I am using Altera DE2 board. For pin assignments, I only use four red LEDs on the board. After I program .sof file by selecting Tool > Programmer from Menu bar, there are others LEDs are blinking. Same as 7 segment display. How to disable all unused LEDs and 7 segment display? Thanks!4 Replies
--- Quote Start --- you might just want to assign led[7:5] = 0; and all HEX(seven seg displays) values to 1 since they are active-low. --- Quote End --- Well if he's not using the LEDs, they shouldn't have a pin assignment. So he can't set them to 0. Ofcourse you can try to make these assignments and see if that works. - Altera_Forum
Hi, Thormodo!
Thanks for reply. For the Device and Pin Options settings, I have set it as tri-stated. But the unused LEDs keep blinking. May I know how to solve this problem? Any hardware coding or setting i need to do beside the device and pin options? - Altera_Forum
If you go to your project navigator (top right corner) of your Quartus project, right click on the name of the FPGA -> Device and pin options ->Unused pins. Does it say As tri-stated with weak pull up, otherwise your LEDs might be floating?
Hi,terasic,
Thanks for the reply. Here is the attachment of my project. I use verilog code to for 32 bits up counter. I connect some 4 bits from 32 bits up counter to a 4 bits of 2:1 mux, and the 2:1 mux outputs connect to 4 leds. I dont do anything for 7 segment display. thanks!
