15 years agoHow to disable all unused LEDs and 7 segment display on DE2 board?
Hi, I am using Altera DE2 board. For pin assignments, I only use four red LEDs on the board. After I program .sof file by selecting Tool > Programmer from Menu bar, there are others LEDs are bl...
15 years ago --- Quote Start --- you might just want to assign led[7:5] = 0; and all HEX(seven seg displays) values to 1 since they are active-low. --- Quote End --- Well if he's not using the LEDs, they shouldn't have a pin assignment. So he can't set them to 0. Ofcourse you can try to make these assignments and see if that works.
