16 years agoHow to debug tcl script files?
I have searched for information on how to debug tcl script files for Quartus, but found none! Background: Some tcl script files generated by sopc builder such as those from DDR2 instantiations...
16 years ago --- Quote Start --- I have searched for information on how to debug tcl script files for Quartus, but found none! Background: Some tcl script files generated by sopc builder such as those from DDR2 instantiations "altmemddr_0_pin_assignments.tcl", did not function as I expected. So I thought there ougth to be some tools to assist. Can it be true that there is not a debug tool or method? Consider the complexity of some of those files (see for instance "altmemddr_0_phy_ddr_pins.tcl" generated by the DDR2 wizard)! How do you solve this problem in your workflow? --- Quote End --- Hi Larsen, as far as I know there is no debugger for TCL available. But what is your problem. Is a syntax error reported ??? Did the controller did not run ??? Kind regards GPK
