15 years agoHow to deal with this warning?
Hi Dears: Below is the warning info: "Warning: PLL cross checking found inconsistent PLL clock settings: Warning: Clock: inst2|altpll_component|pll|clk[0] with master clock period: 2...
15 years ago --- Quote Start --- Hi Dears: Below is the warning info: "Warning: PLL cross checking found inconsistent PLL clock settings: Warning: Clock: inst2|altpll_component|pll|clk[0] with master clock period: 20.000 found on PLL node: inst2|altpll_component|pll|clk[0] does not match the master clock period requirement: 10.000 Warning: Clock: inst2|altpll_component|pll|clk[1] with master clock period: 20.000 found on PLL node: inst2|altpll_component|pll|clk[1] does not match the master clock period requirement: 10.000 Warning: Clock: inst|altpll_component|pll|clk[0] with master clock period: 20.000 found on PLL node: inst|altpll_component|pll|clk[0] does not match the master clock period requirement: 10.000" I am using ArriaGX, and implemented two PLLs in my project. The FPGA's input clock is 100Mhz, which input to the first PLL. The first PLL's outputs are 2 100Mhz (one for internal logic clock, another for external memory clk) clock and 1 200Mhz for SignalTapII sample clock. The sencond PLL's input clock is the first PLL's output that used for internal logic. Thanks in advance! --- Quote End --- Hi, how did you define the input clock of the pll's ? Kind regards GPK
