13 years agoHow to create a programmable clock in RTL(Verilog)
Hello, I'd like to be able to program a clock signal to be used internally for clocking other RTL blocks inside a Stratix FPGA. I have a 500 MHz system clock generated by an internal PLL and wo...
13 years ago --- Quote Start --- A more generic way would be to use two integers, a and b, with b > a. Then the algorithm would be (in pseudo code): on each clock cycle: if (accumulator > b-a) accumulator = accumulator + a - b generate a pulse on clock output else accumulator = accumulator + a end if This will generate a pulse with a frequency of Fsys * a / b If instead of a pulse you change the sign of the output, it will generate a rectangular signal with a duty cycle as close as 50% as you can get, with a frequency of Fsys * a / (2*b) Be careful if you plan to use this generated signal as a clock inside the FPGA itself, as you could have problems with glitches. [daven....I intended to use the generated clock as the real clock signal inside the FPGA! The frequency resolution does not have to be fine at 1 HZ ( can be in KHz) as along as the clock can be used to clock logics....Thanks again...daven]
