13 years agoHow to create a programmable clock in RTL(Verilog)
Hello, I'd like to be able to program a clock signal to be used internally for clocking other RTL blocks inside a Stratix FPGA. I have a 500 MHz system clock generated by an internal PLL and wo...
13 years agoA more generic way would be to use two integers, a and b, with b > a. Then the algorithm would be (in pseudo code):
on each clock cycle: if (accumulator > b-a) accumulator = accumulator + a - b generate a pulse on clock output else accumulator = accumulator + a end if This will generate a pulse with a frequency of Fsys * a / b If instead of a pulse you change the sign of the output, it will generate a rectangular signal with a duty cycle as close as 50% as you can get, with a frequency of Fsys * a / (2*b) Be careful if you plan to use this generated signal as a clock inside the FPGA itself, as you could have problems with glitches.
