How to constrain the GPIO IP core of a Stratix 10 device
- 3 years ago
Thanks for sharing. Seems like the inverter is needed so that the output data can be captured on clock falling edge in order to form full cycle latch for larger setup requirement.
Check the link below Full-Rate or Half-Rate DDIO Input Register .sdc Command Examples:
Image:
Probably can help you out.
Sheng
Thank you very much for your reply.
In fact, there is no violation of DDIO's timing. The main thing is that the path from DDIO to the core register has a timing violation.
But I saw a solution in the AN911, which is that the core registers are also latch with the falling edge of the clock. This helped my design a lot and I've successfully solved the issue.
Thanks again for your reply.
- ShengN_altera3 years ago
