KCMurphy's avatar
KCMurphy
4 years ago
How to constrain a ADC input to a narrow delay window Arria 10
I have an external ADC which I need to sample with an internally generated clock. Reasons. The ADC data conversion is driven by a clock I output, and I would like to sample it with a derived clock at some phase angle.
To do this reliably, I need to be able to constrain both the output clock and the input data paths to some known delay window. At first blush it looks like set_max_delay and set_min_delay would do the trick, but those directives seem to be aimed at setup and hold time respectively, which is not what I want. I simply want to control the routing so that the delay is known (and repeatable).
I can set skew, which is nice, but I still need to constrain the delay time.
  • VenT_Altera's avatar
    VenT_Altera
    Ven Ting
    p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
  • KCMurphy's avatar
    KCMurphy
    Never mind. Did some more reading and set up a proper input delay
