Jiayi_H_Intel
3 years agoHow to change datawidth of DMA Controller Intel FPGA IP
Hi expert,
I want to change the data width of read master and write master, but it seems there is no way to change it. Do you know how to change that?
Long time ago, I successfully change...
hareesh
3 years agoHi,
Small doubt, in you previous DMA (128 bit support IP) can able to trans for 128 bits, because this ip design can support only 8 bit's only. did checked that?
Thank you,
- Jiayi_H_Intel3 years ago
Yes. It can transfer 128bits and worked perfectly well. I have also tested it on FPGA board.
You can double check with the IP I sent to you.
