Jiayi_H_Intel
3 years agoHow to change datawidth of DMA Controller Intel FPGA IP
Hi expert,
I want to change the data width of read master and write master, but it seems there is no way to change it. Do you know how to change that?
Long time ago, I successfully change...
hareesh
3 years agoHi,
go through this document. if you see here quadword support 128 bit.
may i know which version did you used previously?
Jiayi_H_Intel
3 years agoYou can see my snapshot, I have already enabled quadword, but readdata is still 8 bit.
I am using Quartus 21.3 and 21.4.
BTW, you can check the "show signals" box in your picture to see the signal width. Is it a 128bit width?
