sstrell
3 years agoYou probably just need to change a parameter. Reopen the parameter editor for the IP (may be a .qsys or .ip file depending on if you're using Standard or Pro) and change the parameter. Most IP like this and their parameters are documented here: https://www.intel.com/content/www/us/en/docs/programmable/683130/22-3.html
Jiayi_H_Intel
3 years agoBut there nowhere to change it in parameter editor:
BTW, I am not using blackbox.
