14 years agoHow to build a memory?
Hi , I have to write VHDL code of a memory.
the function is : there just 2 states,read and write. if we=1 , the data are wrote into the memory, otherwise it always shows read state ,that means the data_out shows the data which are stored in the memory. There are 5 inputs: clock, enable, write(we), data_in (width of d bit),address (width of c bit) and one output : data_out (width of d bit) I have to use lots of same unit of single memory cell which can only save 1 bit (I was told to use RS-flip flop but I don’t know how) and unit demux to build the whole memory. That means use separate demux, single-cell memory entities etc. Without use ram block which already in FPGA existed. Does anyone can help me or give me some ideas?3 Replies
how about without use Megafunctions?
Also there are some really nice tips here, to get it generated using VHDL only.
http://www.altera.com/literature/hb/qts/qts_qii51007.pdf (http://www.altera.com/literature/hb/qts/qts_qii51007.pdf) - Altera_Forum
Have you looked into using the altsyncram megafunction, using the Quartus Megafunction tool?
