16 years agohow to assign the pin for DDR sdram?
hi,everybody. I want to use ddr sdram. how to set the I/O standard in pin planner? All the pins, i mean,the data, address,control signals must be set to sstl2? thanks.
16 years agoIn pin planner, in the pin list at the bottom, there is a column called I/O standard. You can set it there.
