How to assign pin as a clock?
I have been using MAXII and MAXV CPLDs for some time, but have just started transferring to a MAX10 FPGA. I have started with some simple logic to generate clock signals and I get project compiles with numerous warnings about the pin that I am using for the clock input. I am using 10M08SCU169A7G FPGA with a 30Mhz oscillator connected to ball H6 (CLK0p). This pin is the clock input to an ALTPLL block. Although the project builds and runs correctly, I get the following warnings:
"Node: CLK0p was determined to be a clock but was found without an associated clock assignment"
"The master clock for this clock assignment could not be derived. Clock: inst|altpll_component|auto_generated|pll1|clk[0] was not created."
"Virtual clock CLK0p is never referenced in any input or output delay assignment".
There are numerous other warnings about no clocks defined.
I also want to assign the output of the PLL as a global clock and the fitter is ignoring that assignment.
Although when I load the project it seems to be functioning correctly, it certainly seems as though I am doing something wrong. It also seems that the timing analysis is not working because "inconsistent clock settings".
I have searched the forums and followed the sample projects and I can't find any information on this.
How do I correct these warnings?
It sounds like you have not created a timing constraints file (.sdc) for the design. Once your clocks and I/O delays are constrained, you won't get those warnings anymore. To learn about SDC and creating timing constraints, start here:
https://www.intel.com/content/www/us/en/programmable/support/training/course/odsw1115.html
#iwork4intel
- AnandRaj_S_Intel
Really appreciate Kevin,
Thanks for sharing the solution.
- KVane4
I did have an .sdc file but the clock was not properly defined. I fixed that and the warnings went away.
Thank you for your help.
- sstrell
#iwork4intel
