9 years ago
How to archive Quartus Project using commands promt (inside and outside of Quartus)?
Hi All,
1) How can I archive the Quartus Project from commands prompt?
2) How can I archive the Quartus Project externally (not from Quartus)? Let's say from a linux shell or using windows's *.bat file?
Thank you!
    Try:
    quartus_cdb amp --hc_archive=my_archive
    It should work with a project already compiled with the GUI.
    Cheers,
    Alex
    When running the "quartus_cdb amp --hc_archive", I'm receiving the following error message:
    Info: Command: quartus_cdb amp --hc_archive
    Error (39003): Run Analysis and Synthesis (quartus_map) with revision "amp" for
    --rev option before running Compiler Database Interface (quartus_cdb)
    Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings
    So, what's the whole flow? Should I always run the quartus_map command before the quartus_cdb even the project was compiler, synthesized and mapped from the GUI?
