9 years agoHow to archive Quartus Project using commands promt (inside and outside of Quartus)?
Hi All, 1) How can I archive the Quartus Project from commands prompt? 2) How can I archive the Quartus Project externally (not from Quartus)? Let's say from a linux shell or using windo...
9 years agoWhen running the "quartus_cdb amp --hc_archive", I'm receiving the following error message:
------------------------------------------------------------------------------------------ Info: Command: quartus_cdb amp --hc_archive Error (39003): Run Analysis and Synthesis (quartus_map) with revision "amp" for --rev option before running Compiler Database Interface (quartus_cdb) Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings ------------------------------------------------------------------------------------------ So, what's the whole flow? Should I always run the quartus_map command before the quartus_cdb even the project was compiler, synthesized and mapped from the GUI?
