15 years ago
How i can create a megafunction
Hello, I was doing my project of FPGA, and i need to put a demux in my project, I was trying to find in the library of quartus II, but i didn't find, then i wanna create a megafunction.
Someone can explain how i can create a megafunction, because i tried, but i don't know how to do. I wann create a megafunction of demux with 3 selectors input.
I will always be thankfull.
Thanks for all!!:D
    Oow, i am using schematic! I understood, and i did *----*
    thanks! thanks thanks!!!!!
    Probably you misused the Megafunction term.
    A megafunction is programmable by the user.
    You probably need a hierarchical design.
    If this is the case you can design your demux using schematic and logig gates and then convert it to a symbol that you can use in your top level schematic.
    The same can be done if you degign your demux using Verilog or VHDL.
    Depends on your design entry method. In HDL design entry, definition and instantiation of modules (Verilog) respectively components (VHDL) is a pretty basic language element, so I guess, you're referring to schematic entry.
    Here you can also create hierarchical sheets. Draw your intended sub-entitity (the demux logic) save it under a meaningful name and create a symbol for it, either using the default layout or by individually defining the shape. Then you can place instances of this "MegaFunction" in your top schematic or another sub-entity.
