15 years agoHow i can create a megafunction
Hello, I was doing my project of FPGA, and i need to put a demux in my project, I was trying to find in the library of quartus II, but i didn't find, then i wanna create a megafunction. Someone...
15 years agoDepends on your design entry method. In HDL design entry, definition and instantiation of modules (Verilog) respectively components (VHDL) is a pretty basic language element, so I guess, you're referring to schematic entry.
Here you can also create hierarchical sheets. Draw your intended sub-entitity (the demux logic) save it under a meaningful name and create a symbol for it, either using the default layout or by individually defining the shape. Then you can place instances of this "MegaFunction" in your top schematic or another sub-entity.
