15 years agoHow i can create a megafunction
Hello, I was doing my project of FPGA, and i need to put a demux in my project, I was trying to find in the library of quartus II, but i didn't find, then i wanna create a megafunction. Someone...
15 years agoProbably you misused the Megafunction term.
A megafunction is programmable by the user. You probably need a hierarchical design. If this is the case you can design your demux using schematic and logig gates and then convert it to a symbol that you can use in your top level schematic. The same can be done if you degign your demux using Verilog or VHDL.
