14 years agoHow does the accelerometer in DE0-Nano work (in words)?
I was just wondering, how would you describe the function of the accelerometer in the DE0-Nano card? No code, just description in words please :)
14 years agoThank you for your reply mbharat. Can you please check if this statement is correct then?
The accelerometer is a Micro ElectroMechanical System (MEMS) type. It has capacitors whose one end is fixed, the other is attached to a moving mass. The capacitor is linear, resulting in a charge that is subject to the equation (1) q = C v where q is charge, C is the capacitance and v is the potential difference. For a parallel plate capacitance is given by (2) C = ε_0 A / d where A is the plate area and d is the distance between the plates. The potential difference V between the plates can be expressed as (3) v = Ed where E is the electric field strength between the plates. By substitution of these to the original formula for q, we get (4) q = C v = ε (A/d) (Ed) = εEA = εɸ where ɸ = EA is the electric flux through the surface. As the capacitor charges to the change of q be power, i_c = dq / dt. By deriving the equation above with respect to time, we get (5) i_c = (dq)/(dt) If we put together the equations we have now we can get the displacement current in the area between the plates of the capacitor: (6) i = C (dv/dt) + v (dc/dt) This displacement current is what is reflected and ADXL345 accelerometer used for the measurement of acceleration.
