10 years ago
how do I generate 32k clock from cyclone V pll
How do I use altera pll to generate 32k frequency in cyclone V? I need help for this one.
    @ak6dn Doesn't work like that... The first multiply/divide counter (M/N) sets the VCO frequency. The VCO frequency must be at least 600MHz.
    The lowest frequency the PLL output will do is around 1.6MHz. For lower clock frequencies, this should be done in logic, either to make a clock enable, or a low frequency clock as I said in my earlier post.
    --- Quote Start ---
    --- Quote End ---
    That is true for a single, direct PLL output clock. However, for Cyclone V you can use 'cascade counter mode' where you take pll_output_0 at 8.0MHz, for example, and use that as the source clock to pll_output_1 in cascade mode, and then set the divisor to (in this case 250) to generate 8MHz/250 = 32KHz on pll_output_1. It takes two PLL outputs to do this, but it allows for much higher clock division ratios (ie, up to 512*512).
    Reference, ALTPLL IP User Guide, version 2014-08-18, page 28:
    --- Quote Start ---
    pll output counter cascading
    In 28 nm devices, a C-counter input can be either a VCO output or the cascaded output of a neighboring
    C-counter. Cascading C-counters increase the possible division factor, enabling very low frequency PLL
    output clocks.
    --- Quote End ---
    In the QSYS IP wizard, select two PLL clock outputs, and tick the 'cascade mode' box on output 0 to feed it into output 1 source.
    Ok, here it is in Quartus 16.0:
    http://www.alteraforum.com/forum/attachment.php?attachmentid=12556&stc=1
    --- Quote Start ---
    The device handbook describes the limits for the PLL constants. You must stay within those limits. I suspect 250 is too large a divisor.
    --- Quote End ---
    Thanks for the replying. every one here is correct but I find when I choose "Enable physical output clock parameters" which can show M,N.C values, it doesn't allow me to "finish". Does any one know why?
    Jeff
    It should be generating an error message in the 'message' window if it does not like some parameter value or values.
    You might have to take a screen shot of the problematic window and post it.
    What version of Quartus are you using?
    --- Quote Start ---
    --- Quote End ---
    I got it. Thanks a lot.
    -Jeff
    --- Quote Start ---
    @ak6dn. Did not know that. Thanks, very informative! :)
    --- Quote End ---
    Altera does not always make it easy to find new and useful features :(
