AMess8's avatar
AMess8
6 years ago
How can I revert to old firmware on EthernetBlaster II?
​I have an EthernetBlaster II that requires an older version of the firmware to be loaded because of compatibility constraints. 519_179 is the version I am trying to restore to. When I do load the firmware through the web interface the device becomes inoperable. I cannot connect to the configuration page, the status LED is "breathing" yellow, and the factory reset button does engage a reboot.
  • JohnT_Altera's avatar
    JohnT_Altera
    It looks like your EthernetBlaster II is bricked and not recoverable anymore as it is not able exit reset.
    JohnT_Altera
    May I know could you hold the reset and power on the blaster before releasing it?
    • AMess8's avatar
      AMess8
      Holding down the reset button, applying power, and then releasing the reset does not recover it.
    JohnT_Altera
    Hi.
    Could you try to hold the Machine Reset to see if you are able to reset the blaster? The reason is that you need to make sure that your blaster has green led before you are able to proceed with firmware changes.
    • AMess8's avatar
      AMess8
      The LED was steady green when I loaded the firmware. After loading, the LED turns yellow and pulses. After this, the LED never turns green even after pressing/holding reset. Cycling power does not restore. Also no connection through Ethernet.
