AMess8
6 years agoHow can I revert to old firmware on EthernetBlaster II?
I have an EthernetBlaster II that requires an older version of the firmware to be loaded because of compatibility constraints. 519_179 is the version I am trying to restore to. When I do load the fi...
JohnT_Altera
6 years agoHi.
Could you try to hold the Machine Reset to see if you are able to reset the blaster? The reason is that you need to make sure that your blaster has green led before you are able to proceed with firmware changes.
AMess8
6 years agoThe LED was steady green when I loaded the firmware. After loading, the LED turns yellow and pulses. After this, the LED never turns green even after pressing/holding reset. Cycling power does not restore. Also no connection through Ethernet.
