16 years agohow can i get about 100Mbps~200Mbps TCP traffic using Ethernet ?
Hi : I want to use Ethernet to transmit huge of data (after AD processing) to PC. It is better to get about 100Mbps~200Mbps TCP traffic .I think it's hard for Nios II system to get this speeed...
16 years ago --- Quote Start --- I didn't found this example. Where in wiki nios is it? --- Quote End --- Hi, in Wiki Nios page, try to search for "udp". You will find some links, take a look at those with the tags "udp" and "offload". There is a documentation (some explain about the code) and the example (code and an executable). Hope it can help you :D
