16 years agohow can i get about 100Mbps~200Mbps TCP traffic using Ethernet ?
Hi : I want to use Ethernet to transmit huge of data (after AD processing) to PC. It is better to get about 100Mbps~200Mbps TCP traffic .I think it's hard for Nios II system to get this speeed...
16 years ago --- Quote Start --- nioswiki has a great example using UDP. The example gets line rate at 1Gbps. --- Quote End --- I didn't found this example. Where in wiki nios is it?
