17 years agoHow can I generate a reset signal?
Many IC need a reset signal to initialation, but when I write codes in FPGA, the Quartus will stick the signal to a fixed level, the code is as below: input clk; output reset; reg reset;...
17 years ago --- Quote Start --- Many IC need a reset signal to initialation, but when I write codes in FPGA, the Quartus will stick the signal to a fixed level, the code is as below: input clk; output reset; reg reset; reg[3:0] cnt; always @ (posedge clk) begin if(cnt<10) begin reset<=0;cnt<=cnt+1; end else begin reset<=1; end end The Quartus will stick reset to vcc, who can help me how to generate a reset signal? Thanks very much! --- Quote End --- Hi, the behaviour of your counter is only predictable if we assume that after power-up all registers will have a defined state. I would re-write the code a little bit: module reset (clk, reset,reset_int ); input clk; input reset; output reset_int; reg reset_int; reg[3:0] cnt; always @ (posedge clk) begin if (reset) begin cnt <= 0; reset_int <= 1; end else if(cnt<10) begin reset_int <=0; cnt<=cnt+1; end else begin reset_int <=1; end end endmodule You need an input reset signal in order to bring your design (also your reset generator) in a defined state. In our example the counter would run only one time after power up and your pulse length depends on how the registers a powered up. Worst case you will never get an reset pulse. I don't know how the power-up sequence of the FPGA's lookslike, but would never write a design which depends on it. I have a small Quartus Project attached. Kind regards GPK
